4 members (wilbur53, klhansen, Steelonsteel, Bill Hanlon), 141 guests, and 2 robots.
Topics128,266
Posts1,058,368
Members48,485
#29791 04/23/2002 1:58 PM
Hey all,
I have an 89mm shifter handle that I want to remove from one shifter and transplant to another factory shifter. I removed the bolt and the shifter handle won't budge. How do I remove the old shifter handle? Does it have to be forced out?
Any help would be appreciated as I have a freshly rebuilt unit I'm ready to bolt in and roll.
Thanks!
-wftyler
#29792 04/23/2002 6:17 PM
THe shifter that came with mine had no bolt. It used spring clips on the side. Just slide a thin screwdriver down alongside the shifter to release the clip and pull the handle out.
http://www.homestead.com/chuckthetruck/files/xKmrv_011.jpg
#29793 04/25/2002 11:31 PM
Hey chuck,
I've tried everything and the shifter still won't budge. My shifter appears to be the exact same as your first one. I even took it to 3 different transmission shops and they had no clue.
-ftyler
#29794 04/26/2002 11:26 AM
I think it may be a common problem - mine looked like someone previously had gotten out their frustrations with a hammer. If you look into the "receiver" down alongside the stick, you should see a metal clip and a bit of rubber on each side. There is a barb in the center of the steel clip that engages a small recess in the stick. Use thin screwdrivers, slivers of sheet metal, a steel rule, whatever and slide it down next to the stick (both sides). You should feel when it passes and pushes back the barb. The stick will then pull out with practically no effort. I made a sketch at
http://chuckthetruck.homestead.com/files/shifter.jpg
#29795 04/26/2002 1:09 PM
ok. Will try again the RIGHT way smile this time. Thanks chuck.
#29796 05/07/2002 11:29 PM
My shifter was different from Chuck's. Mine had two pins through it- punched them out and shifter lifted up just fine. Drilled out and replaced with bolts.
