| | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29766 12/18/2004 3:06 AM | Joined: Jun 2004 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 103 | OK - My '51 (216) chewed up a few (5)teeth from the camshaft gear but still ran with a heavy knocking sound. Got it torn down to discover insert bearings and .040 over size pistons / sleeved cylinders. I had ordered (Jim Carter - STD)rod bearings prior to tear down. Discovered that I needed .010 undersize bearings. Jim Carter did have in stock - ordered from Kanter's and rec'd completely different bearing set for the 216. Lube hole in wrong place (no machined oil groove)and not as wide as replacement set from Carters. Could I have a 216 with (1954)235 connecting rods? Hard to follow up on Previous Owner info. I will leave better records of what I do on this truck. A promise. BW | | |
#29767 12/18/2004 4:28 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If your insert bearings are McQuay Norris, the dipper hole isn't as off center as the other brands. However, if the hole is elongated, it is a dipper type insert. The inserts for regular rods are thicker. The dipper inserts are thinner because they take metal off an existing rod design and they don't want to weaken it. I would think that there should be a center groove in the inserts. | | |
#29768 12/18/2004 5:50 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Do your rods use dippers? I would bet you just got the wrong set of bearings.
See the USA in your vintage Chevrolet! My Blog | | |
