0 members (),
139
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29737 01/19/2003 8:59 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | JUST GOT FINISHED WITH REDRYDER ANDIT WILL MOVE NOW, TOOK IT FOR A SHORT RUN AND EVERYTHING SEEMS TO BE TIGHT AND ALRIGHT, JUST WANTED TO SAY THANKS TO MECHAINIAC,WANNABE,DR.FATFENDERS,TONY,OLY,BARRY WEEKS,PTE359,BRIAN MOORE,OLE BLUE TRUCK,4 ON THE FLOOR,JOHN MILLIMAN(DECIDED NOT TO SELL IT) LOE BIG, T, MOTT, CHIPHEAD AND OTHERS FOR THE SUPPORT ALL HAVE GIVEN ME ON MY FRIST ATTEMP TO REPLACE UJOINT IN A CLOSE DRIVE SHAFT,IAM OLD AND SLOW BUT WE ALL GOT IT DONE,THANKS AGAIN,,,,,FRED Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#29738 01/20/2003 2:08 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Congratulations to you and a big thank you for being part of the bolt
#29739 01/20/2003 3:53 AM | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | Fred, CONGRATULATIONS!!  Glad to hear Redryder is movin' again. No thanks necessary to me..it's these other guys who actually have torque tube driveline experience to thank. Besides, encouragement is about 1/2 the battle, in my books. Now go have a nice hot shower and relax, knowing your old fella is fixed up. Regards, Wannabe
"Don't expect anything and you'll never be disappointed"
#29740 01/20/2003 4:22 AM | Joined: Dec 2001 Posts: 31 Member | | Member Joined: Dec 2001 Posts: 31 | Glad to hear it was as simple as a u-joint! They sure do weigh less than a trany Enjoy cruising!
Thomas Mott 1949 GMC 250 1957 Dodge COE c-700 1959 Chris Craft 17' w/big journal 327 for more power
#29741 01/20/2003 4:25 AM | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | joker we are here to make sure that success stories like your continue on and on and on! Good Job!
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#29742 01/20/2003 10:38 PM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | My name wasn't mentioned, cause I didn't contribute maybe? Anyway, STOP Shouting (capitals). We can all hear fine at regular fonts.  :p :p
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
#29743 01/21/2003 1:07 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | GL, that is why I said others, just in case I missed some one, I DO NOT UNDERSTAND WHY CAPS IS A BIG thing with you, it was just to get attention and I guess that it work.....have a good night and a better tomorrow.....Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#29744 01/21/2003 1:17 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | All caps are hard to read on most computer screens. It makes all the words run together.
#29745 01/21/2003 3:08 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | ok, I will keep that in mind the next time I post,
#29746 01/21/2003 4:49 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Feel free to use caps again, its funny when GL goes on a tear.
So what happened, bolts back out of ujoint or what?
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#29747 01/21/2003 11:40 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Chip, the back spline was broke at the j- joint, I screwed something up, I drove it for a few miles and all was well, I drove it to work today and noticed oil,(Fluid)underneath,I got home ok but it was hard to shift, the u-joint area seem to be making a clunking sound so I will go into it again, I did not see it leaking yesterday when I drove it but....question, where the speed cable goes into tranmission, and then where the plug is on the side of the transmission, is this two separate areas as far as filling the fluid level? or will one take care of both needs, I was real careful when I put everythng back, I could not believe it but anyway,,,,thanks for your RESPONSE,..I feel kind of stupid, luke took time to explain everything to me, even called him long distance, I just knew that I had it right, well as they say, s### happens, later, Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#29748 01/21/2003 11:57 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | You running the torque tube, or a conversion or something right?
The tranny fill plug should fill the entire tranny, output shaft, speedo gear, etc. Now if you're using an open driveline tranny with a closed driveshaft adapter, I don't know how oil is supposed to get to the closed u-joint.
Did the ujoint break where it slides onto the torque tube shaft? Weird.
This time, did you loc-tite the bolts in, and bend the keepers over the bolt heads? Feel any vibration before she cut loose this time?
good luck chip
#29749 01/22/2003 12:40 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | chip, it is a closed stock 52 drive train. the reason I asked was the book said to fill the speed cable plug area, I did not do this, but the transmission plug area seemed to be ok,these did not have bent locks, just 2 bolts with a self made retainer in them,I am back at work, but I did tighten the 4 collar bolts again,I do not have a torque wrench and I did make a turn or two on each one, I refilled the speed cable area but It will be late tomorrow afternoon before I hook up the gear shift and floor board area,should I use some blue permtex around this collar gasket area, I trying this before I undo the collar and u- joint area, If it is not noisy,I will drive and check for leaks, I know for sure that it does not leak when it is sitting still. I will be checking the bolt thru out the night for any response,,,,thanks,...Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#29750 01/22/2003 4:35 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Drive the truck really slow up & down your street. If you hear any noises, you'll have to slide the Ujoint bell back and make sure the ujoint assy is still OK. If the Ujoint is OK, look forward at the tranny, or behind the ujoint at the T-tube or rear axle.
I've grenaded a few ujoints in my '54, but every time it was the 4 bolts that hold the ujoint together. Its weird that your ujoint would experience breakage failure at the splined part. If it happens again, you'll have to delve deeper to find the root cause.
Your problems could either be improper installation of the replacement parts, or a more serious problem we haven't thought of yet.
good luck
chip
#29751 01/23/2003 12:46 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Chip, I just tried out the 52 after topping off the fluids, did not have to drive it down the street, just had to back up and go forward a little and could tell that I need to undo everyting again,the truck will move the trouble tells me something is about to come undone,we had a cold front come in so it may be a few more days before I go into it, man,it drove and sounded good for 6 of the 8 miles. thanks for all of your in-put,I may start searching for the best match for changing the rear end, transmission out,etc.later.....Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
