9 members (Otto Skorzeny, Cosmo, RAC1812, cmayna, GRNHydra, HandyAndy, Peggy M, 1955 1 Series, 1 invisible), 144 guests, and 1 robot.
Topics128,087
Posts1,055,982
Members48,430
#29729 09/11/2004 9:57 AM
Has anyone ever replaced the threaded pin/metal bushing setup with a rubber or polyurathane bushing? I'm thinking of going this route on my 52 3100 1/2 ton but haven't been able to find a manufacturer online that lists the ID and OD of their bushings - they all seem to do it by vehicle type/year only. If I could find a bushing with a 7/8" OD and a bolt hole in the middle I'm pretty sure I could get it to work.
It seems like a modern bushing setup would give a slightly softer ride, less maintenance, and allow the shackle to be attached at both ends instead of only by the bolt in the middle. Thoughts?
Keahi
Did that on the front of my 37. I went to a local rod shop,got the bushings and shackles.Jegs or Summit has stuff like that too.
The stock front shackles on our truck were thrashed, probably from lack of regular lubrication. I searched catalogs ond web sites like "energy suspensions", but had no luck finding urethane replacements. They don't like to tell you the dimensions of their products
So I bought some Delrin rod. Delrin is a plastic like hard teflon. After a couple of hours of work on my brother's lathe I had a new set of bushings. The truck has not been on the road since the modification so I can't tell how well they are wearing, but this is tough stuff.
In the rear, I am using springs from a Blazer, so I am using urethane bushings from "Energy Suspensions"
Gord
1954 1/2 ton 235 4 speed
Thanks for the the tips! I went to various performance places today and measured the urathane bushings they had in stock and found everything was too big.
I've noticed that too. I've been doing a lot of internet searches and I *think* early jeep springs (CJ2A?) may have 7/8" inch eyes like our trucks. I'm not too concerned about spring width as I could always cut them down to fit. I'll post what I find.
Keahi
