10 members (5 Window 9434, cmayna, 78buckshot, Samantha, DJMTruck, dt235sd, Opelika Tom, Gdads51, HandyAndy, 1 invisible),
94
Mod | | | Forums66 Topics128,062 Posts1,055,847 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29729 09/11/2004 9:57 AM | Joined: Dec 2003 Posts: 74 New Guy | | New Guy Joined: Dec 2003 Posts: 74 | Has anyone ever replaced the threaded pin/metal bushing setup with a rubber or polyurathane bushing? I'm thinking of going this route on my 52 3100 1/2 ton but haven't been able to find a manufacturer online that lists the ID and OD of their bushings - they all seem to do it by vehicle type/year only. If I could find a bushing with a 7/8" OD and a bolt hole in the middle I'm pretty sure I could get it to work.
It seems like a modern bushing setup would give a slightly softer ride, less maintenance, and allow the shackle to be attached at both ends instead of only by the bolt in the middle. Thoughts?
Thanks, Keahi | | |
#29730 09/11/2004 11:26 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Did that on the front of my 37. I went to a local rod shop,got the bushings and shackles.Jegs or Summit has stuff like that too. | | |
#29731 09/12/2004 4:47 AM | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | The stock front shackles on our truck were thrashed, probably from lack of regular lubrication. I searched catalogs ond web sites like "energy suspensions", but had no luck finding urethane replacements. They don't like to tell you the dimensions of their products
So I bought some Delrin rod. Delrin is a plastic like hard teflon. After a couple of hours of work on my brother's lathe I had a new set of bushings. The truck has not been on the road since the modification so I can't tell how well they are wearing, but this is tough stuff.
In the rear, I am using springs from a Blazer, so I am using urethane bushings from "Energy Suspensions"
Gord 1954 1/2 ton 235 4 speed
#29732 09/12/2004 8:45 AM | Joined: Dec 2003 Posts: 74 New Guy | | New Guy Joined: Dec 2003 Posts: 74 | Thanks for the the tips! I went to various performance places today and measured the urathane bushings they had in stock and found everything was too big.
I've noticed that too. I've been doing a lot of internet searches and I *think* early jeep springs (CJ2A?) may have 7/8" inch eyes like our trucks. I'm not too concerned about spring width as I could always cut them down to fit. I'll post what I find.
Keahi | | |
