3 members (1955 1 Series, TUTS 59, 1 invisible), 141 guests, and 1 robot.
Topics128,162
Posts1,056,934
Members48,458
#29720 01/20/2005 5:33 AM
I overhauled my 216. I got it all back togather and now it wont start.
I made shure the timing marks were right, I put the distributer in the way it is supose to be. can any one help me?
1956 Chevy 3600
“Maynard”
In the DITY Gallery
More pictures on Flickr
#29721 01/20/2005 5:58 AM
Junior Member
Junior Member
Always start with the basics: Fuel, Compression, Spark. Work from there.
The old motors are forgiving and will let you know what is wrong.
May the Stovebolt God be with you smile ND
#29722 01/20/2005 2:07 PM
Junior Member
Junior Member
Bart,
I just got done with my 216. If talking it through would be of value to you, call me at about 6:30 today and I will try to help.
I am in Texas and my number is (512) 444-5449.
Michael
#29723 01/20/2005 2:36 PM
Bart,
Do you have spark?
#29724 01/20/2005 8:23 PM
First check your dstributor.
It happened to me more than one time when I had the dizy out. I was always 100% sure I did it the right way.
The tricky thing is if you check for spark you will see spark but you have it at the wrong time (exhaust cicle instead of power strock).
Replug the wires 180 degrees and give it a try. That solves the problem in most cases grin
If it works keep it that way or pull the dizzy again and turn the shaft 180 degrees bevore you put it back.
Frank
#29725 01/21/2005 6:28 PM
I apologise for not geting back sooner. I got a sick kid , he hasn't been sleeping much at night, so I havn't been able to get back to the truck. I checked to make sure I was geting fule. she backfired through the carb twice so I think I am geting spark.. I am going back out to check for sure.
Bart
1956 Chevy 3600
“Maynard”
In the DITY Gallery
#29726 01/23/2005 3:57 AM
I am geting power to the points but not to the plugs.
1956 Chevy 3600
“Maynard”
In the DITY Gallery
#29727 01/23/2005 4:15 AM
Bart,
Recheck the set on the distrib, re-gap your points, check the basics like cap, rotor...If you did not change plugs, do so...when I was trying to start mine, the middle of the plugs had corroded. They looked great on the outside, but I broke the top off one taking it out and found out the plugs were junk. I would have never got them to spark.
Like listed above...just go back over the basics....
#29728 01/24/2005 1:48 AM
Thanks everyone, i found the problem. My coil quit.
It was only about six months agao that I changed it.
Bart
1956 Chevy 3600
“Maynard”
In the DITY Gallery
