8 members (delky, val, UtahYork, Otto Skorzeny, mason86, Bill Hanlon, Woodcmiami, 1 invisible),
60
Mod | | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29628 06/08/2003 4:49 AM | Joined: Jun 2003 Posts: 17 Junior Member | | Junior Member Joined: Jun 2003 Posts: 17 | yes I am new on this forum. Hello to everybody .What is happening, is my 283 motor is not running so hot. I think it could be a lot better.The motor hesitates bad on take off hot or cold. I tried moving distributor adjusting carb doesn't help.Would appreciate any help thanks! | | |
#29629 06/08/2003 4:54 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Have you checked the points? (does it have points or HEI ignition? - Welcome to the Stovebolt
#29630 06/08/2003 4:58 AM | Joined: Jun 2003 Posts: 17 Junior Member | | Junior Member Joined: Jun 2003 Posts: 17 | yes It doesn't have points I use a pertronix part in distributor good cap new wires. | | |
#29631 06/08/2003 5:46 AM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | howdy do wane, welcome to the garage! try checkin accel pump - might be gettin wimpy - dem 283's like a good shota juice to jump up and roar - look inside carb for junk from rusty tank that might interfer w/ float needle - check carb inlet screen thingy
Bill | | |
#29632 06/08/2003 4:40 PM | Joined: Apr 2003 Posts: 140 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2003 Posts: 140 | Hesitation on acceleration is *usually* a lean condition. If it's about the same whether hot or cold, I'd check the accel pump first, as another 'Bolter suggested.
Second, look for vacuum leaks. Actually, maybe do that first. 8-) Got a Mityvac or similar? Check every hose and line. Then do the spray-while-running (w/ carb cleaner), listen for RPM changes.
Third, carefully dismantle and clean the carb. Check it for airleaks around the butterfly bores.
Good luck! George
53 3600 | | |
#29633 06/08/2003 9:41 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Wane, what kind of a vehicle is the 283 in ??
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#29634 06/09/2003 8:26 AM | Joined: Jun 2003 Posts: 17 Junior Member | | Junior Member Joined: Jun 2003 Posts: 17 | yes thanks for helping with the engine hesitation problem.It seems like the carb is the culprit,starting checking it already.Hey bill I think you wanted to know what the 283 is in it is a 63 chevy truck fleetside 10 series.The truck is all stock.Thanks again for all your help.. | | |
