1 members (Steelonsteel), 75 guests, and 1 robot.
Topics128,050
Posts1,055,760
In cleaning up my spindle getting ready for the king pin swap, i noticed that the inner race looks a bit on the sorry side. 59 chevy 1 ton.
So whaddyer think?
1. Leave it.
2. Grind it as best you can.
3. Find another.
Spindle pix
This whole axle has been pretty rough. Maybe I should find another, although, it looks ok, and the other spindle is ok. Trying to do those kaiser no ream king pin kit.
Thanks for your opinions/time.
That's a cave man trick to stop the inner race from turning on a worn spindle. Loctite makes a bearing mounting compound you might try. Other wise replace the spindle. Death to cave men!!
if it dosen't need fixed, break it
Yep , I'm with kedso on this one ,, I've used Loctite 620 with success , and where one was really sloppy , I used Loctite 680 , it fills a bigger gap .
This product is hard to disassemble , but the careful application of heat ( say 350deg) will degrade the loctite enough to remove parts .
Irwin, that looks like the bearing race was cut off with a torch, damaging the spindle. I'd find a better one. Jacques
Union, Justice and Confidence
delays delays delays
thanks for the advice gentlemen. I will see what I can scrounge.
Someone had used an air hammer/chisel on the bearing to remove it. REPLACE IT for safe and trouble free operation in your future.
And the resident engineer says replace that spindle. Those weld (or cut) spots are a great location for cracks to start and grow.
Find the p.o., connect one electrode to his tongue, the other to his tallywhacker, and slowly remove him from the gene pool. A 5 amp increase every 30 minutes should do it.
Fred
52 3600
69 C-10
