8 members (walter74, mvigo, Forty9, Shaffer's1950, Rusted Nut, mick53, Wally / Montana, klhansen),
114
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29585 02/18/2003 12:14 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | In cleaning up my spindle getting ready for the king pin swap, i noticed that the inner race looks a bit on the sorry side. 59 chevy 1 ton. So whaddyer think? 1. Leave it. 2. Grind it as best you can. 3. Find another. Spindle pix This whole axle has been pretty rough. Maybe I should find another, although, it looks ok, and the other spindle is ok. Trying to do those kaiser no ream king pin kit. Thanks for your opinions/time. | | |
#29586 02/18/2003 1:36 AM | Joined: Apr 2002 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 146 | That's a cave man trick to stop the inner race from turning on a worn spindle. Loctite makes a bearing mounting compound you might try. Other wise replace the spindle. Death to cave men!!
if it dosen't need fixed, break it
#29587 02/18/2003 1:52 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Yep , I'm with kedso on this one ,, I've used Loctite 620 with success , and where one was really sloppy , I used Loctite 680 , it fills a bigger gap . This product is hard to disassemble , but the careful application of heat ( say 350deg) will degrade the loctite enough to remove parts . | | |
#29588 02/18/2003 2:02 AM | Joined: Sep 2001 Posts: 208 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 208 | Irwin, that looks like the bearing race was cut off with a torch, damaging the spindle. I'd find a better one. Jacques
Union, Justice and Confidence
#29589 02/18/2003 3:14 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | delays delays delays
thanks for the advice gentlemen. I will see what I can scrounge. | | |
#29590 02/18/2003 3:14 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Someone had used an air hammer/chisel on the bearing to remove it. REPLACE IT for safe and trouble free operation in your future.
#29591 02/18/2003 4:46 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | And the resident engineer says replace that spindle. Those weld (or cut) spots are a great location for cracks to start and grow.
Find the p.o., connect one electrode to his tongue, the other to his tallywhacker, and slowly remove him from the gene pool. A 5 amp increase every 30 minutes should do it.
Fred 52 3600 69 C-10
