1 members (stlcardinalsguy),
71
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29576 10/26/2003 4:52 AM | Joined: Jul 2002 Posts: 17 Junior Member | | Junior Member Joined: Jul 2002 Posts: 17 | I have a SBC with HEI I've had to replace 6 modules in the last year We've tried used ones and new after market types they last 1 to 2 3 months at fist it seemed if it was really hot but I;ve had them fail in cooler weather as well we've done the installs with the heat sink grease change distributors I'm out of ideas anybody got some others or have cured the same problem?
48 nick
#29577 10/26/2003 6:36 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Check the output of your voltage regulator and the ground on your engine block. It sounds like the module is getting too much voltage or a bunch of high voltage spikes.
#29578 10/26/2003 9:40 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Good things to check for as mentioned by 4ontheFloor. I am suspecting a bad ground. there is suppose to be a ground lug/strap/pieceofmetal that fits under the coil cover. it attaches to one corner of the coil itself and fits into the slots where the other wires go out to the side of the cap.
#29579 11/02/2003 9:16 AM | Joined: Jul 2002 Posts: 17 Junior Member | | Junior Member Joined: Jul 2002 Posts: 17 | Thanks folks I'll check those areas out although I also heard locally that perhaps the condenser could be at fault.
48 nick
#29580 11/03/2003 4:35 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Also check the engine ground. Josiah mentioned voltage spikes, could also be the coil. Another thought, have you been jump starting the truck?
Fred 52 3600 69 C-10
