5 members (Bill Hanlon, carbking, HandyAndy, dt235sd, Otto Skorzeny), 91 guests, and 3 robots.
Topics128,053
Posts1,055,777
#29533 10/26/2003 4:23 AM
if i want to put a 350 in my 62 chevy half ton, which has the granny first gear four speed, would there be problems? what would i need to do/buy in order for them to function together? thanks...
Then you will know the truth, and the truth will set you free.
- Jesus -
If its the original 4-speed they used the same from 40-something to 67 or so. The differences depended on application, but all you care about is if you have the right belhousing to go between the transmission and the V-8.
I don't remember if the change was for '62 or after '62, the later bellhousing fits both the six and V-8, the earlier does not, and you'll need a pickup type V-8 bellhousing to have the correct mounts to attach it to the frame.
I think...
First off, which engine do you have and does it still have the hydraulic clutch system?
You may need the bellhousing OldSub refers to and the engine mounts, exhaust, other small linkages if you are converting from a 235/261 engine to the 350 engine (or other smallblock V-8).
If your truck has the hydraulic clutch system, you will need to locate a bellhousing for the later style 6 cylinder or V-8 which also has the place to mount the clutch slave cylinder.
What size motor do you have currently? Your bellhousing and clutch will work just fine with the 350. Your motor mounts I think are the only item that may need to be changed if you have a 292 in there now. Since you have a 62 you also should still have the hydraulic clutch but all the clutch parts are the same between the 230/250/292 and the SBC.
1962 would have a last version 235 wouldn`t it?
(unless it had a V-8 grin )
I can never remember. I know '62 was either the last year or the first year...
Good morning my friends!
I see my son has been using my account again.
grin
We're pretty sure this '62 has the 235. And, yes, it has the hydraulic clutch.
Thanks for all the advice. It sounds like more work than I personally want to tackle, but you know teenagers have unlimited optimism!
smile
Who knows? It could work....
- Jesus -
