4 members (Otto Skorzeny, Hotrod Lincoln, 32Fordpuchoptop, Nhluvstruck), 164 guests, and 1 robot.
Topics128,114
Posts1,056,283
Members48,439
Does this method work on the 230s like it does on a SBC? Yes stock motor, hydraulic lifters........
"Loosen until it clatters. Then tighten it back up just until it's quiet. Then tighten down a 1/2 to 3/4 of a turn. Leaving 10 seconds in between 1/4 turns."
lmk,Bill
smile
Sounds good to me.
Remember 9-11-01--God Bless the USA
JUSTICE, not REVENGE, will prevail
1951 Chevy 1/2-ton Pickup truck
Just a little tip that may help. If you have an old valve cover around that you don't care about, cut a whole large enough over each adjuster so a socket will fit through and put it on with a gasket for adjusting. Keeps most of the oil from spattering up your inner fenders and fire wall. The system you described is the one I use, but check your manual for proper back off turns. Could be anywhere from 1/2 to one full turn. Varies with engines. 3/4 is what I see most.
Truck Tinker
Junior Member
Junior Member
When I did mine, I just laid a shop rag over the ones I wasn't adusting... no problem, no mess.
MaydayMike
'64 Biscayne 230/pg
MaydayMike
1964 Biscayne
230, Powerglide, no power nuthin'!
H Online: Content
That method is terribly messy and inaccurate, too. It's much simpler to do the adjustment with the engine stopped. Just be sure the cylinder you're adjusting is on top dead center with both valves closed. Either use the distributor rotor to indicate which cylinder is ready to fire, (top of the compression stroke, both valves closed), or use the "companion cylinder" method I've described several times. You couldn't bribe me to do a running adjustment on a hydraulic-lifter engine!
