8 members (Wickedbass, tclederman, Rusty Heaps, Peggy M, TexasA&M48Truck, Wally / Montana, Gray_Ghost, UtahYork), 115 guests, and 3 robots.
Topics128,066
Posts1,055,876
Members48,428
#29457 01/12/2005 1:50 PM
ok here goes..got three drums off my 50 3100 chevy, but the last one (rear passenger) was stuck solid. not sure when it has been off. I backed-off on adjusters but still stuck. so then I got the bright idea to unhook brake line to wheel cylinder to relieve pressure, did that and still stuck. next I loosened bolts to wheel cylinder and while adjusting they came off and wheel cylinder slipped into drum and now shoes are wedged tight against drum. what can I do to get the drum off?
Blue 50
1950 3100 w/57 235
Patrick’s Saginaw 4 speed and 3:55 rear end
#29458 01/12/2005 2:34 PM
Are you sure that the Drum is free of the Axle? If not take a 3 or 5 lbs malet and hammer outter edge of the face(flat part) of the drum. I usually start at 12 o'clock then 6,3,9 and keep moving around the drum. Once the drum is free from the axle and if it still won't come off try this. Look at the backside of the Backing Plate. Look for the anchor pins that hold the shoes to the backing plate (should be at 6 and 9 o' clock positions). If possible grab hold of the pins (from the back side) pull them toward the opposite wheel and the cut them with a small die grinder or side cutters. This should allow you to pull the drum and shoes off at the same time.
Good luck
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#29459 01/14/2005 2:25 AM
Brian,
a couple of whacks from the mallet and it popped right off....thanks
Blue 50
1950 3100 w/57 235
#29460 01/14/2005 2:29 AM
I Love This PLace!
Buddy in AK
"Keep the shiny side up....."
'50 GMC Suburban
'55 1st Chevy Pickup
http://community.webshots.com/user/buddyinak
#29461 01/14/2005 3:18 AM
Tab Offline
The hammer is an underestimated tool... grin
delete my account and pictures
#29462 01/14/2005 1:09 PM
Apprentice
Apprentice
i have to agree with the others you just need to get a bfh ( big F@$#!ing Hammer)
1940 1/2 ton chevy
#29463 01/14/2005 9:41 PM
Glad that it worked out for you!
Brian Moore
#29464 01/17/2005 3:36 PM
Socket Breaker
Socket Breaker
Yay Brian!
-W
