10 members (Gdads51, Forty9, TexasJim50, TooMany2count, 55shaker, Guitplayer, Otto Skorzeny, Peggy M, Bill Hanlon, cmayna), 145 guests, and 3 robots.
Topics128,259
Posts1,058,292
Members48,485
'54 3/4 ton GMC. I'm looking at a taller rear end. Guy at the wrecking yard says he has a '68 chevy drop out. He's concerned that there may be a difference between my current axel splines vs. the '68 splines. He says one may be fine and one course. Any input?
From what I understand, the 67 to 72 3/4 ton carriers are a direct swap to the 47 to 55 trucks. If the carriers swap, then the splines should be the same. Maybe somebody else can chime in and correct us both.
Ralph
rtlopez@shipleysystems.com
48 Chevy 3600 w/235
48 Chevy 3100 w/235:
You cant see the smoke on a dirt road.
