2 members (Gdads51, WICruiser),
84
Mod | | | Forums66 Topics128,268 Posts1,058,319 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29441 05/18/2005 9:47 PM | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | '54 3/4 ton GMC. I'm looking at a taller rear end. Guy at the wrecking yard says he has a '68 chevy drop out. He's concerned that there may be a difference between my current axel splines vs. the '68 splines. He says one may be fine and one course. Any input? | | |
#29442 05/19/2005 9:07 PM | Joined: Jan 2004 Posts: 255 Member | | Member Joined: Jan 2004 Posts: 255 | From what I understand, the 67 to 72 3/4 ton carriers are a direct swap to the 47 to 55 trucks. If the carriers swap, then the splines should be the same. Maybe somebody else can chime in and correct us both. Ralph | | |
