0 members (), 77 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
#2940 07/26/2003 1:57 PM
During a 1600 mile trip in my 1 ton the rear motor mount let go.
every body sells a motor mount for the 1/2 ton but could not see a listing for a 1 ton. Are the motor mounts the same in 1/2 and 1 ton or not?
Who knows where to find som which would fit?
Fritz Peyerl
Turner valley, Alberta
http://www.badmileage.com
#2941 07/26/2003 4:46 PM
Should be the same as a 3/4 ton..........We are talking about an AD truck, right?
Most auto parts stores will carry stuff for 3/4 ton. Sometimes you have to order stuff for the bigger trucks........that's what makes them harder to restore/maintain.
Hope you get it fixed; it's good to see you are cruising an old 1 ton cool smile
*** GMC ***
#2942 07/27/2003 12:51 AM
yes it is a AD 1ton 1953.
can't find anybody which has 3/4 or 1 ton motor mounts. Any body has any idea where whom to contact.
Will try to take the old one out and take some measurments to see what could be done
Fritz Peyerl
#2943 07/27/2003 2:36 AM
Z
Z Offline
steele rubber products can rebuild your mount.
#2944 07/27/2003 5:23 AM
The Filling Station shows a mount in their catalog. 1939-53 GMC 1/2 to 2 ton, would that be the same
Regards,
Larry
I don't own a vehicle that isn't old enough to drink.
#2945 07/27/2003 5:48 AM
Larry
Thanks for the reply. Have to check that out on monday. I know the 1/2 ton is different.
Fritz Peyerl
#2946 07/28/2003 3:08 PM
Just about any of the vendors have the mounts. I got mine through my local parts store, he had to order them.
Fred
52 3600
69 C-10
