1 members (NJC),
138
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2002 Posts: 91 Member | | Member Joined: Jul 2002 Posts: 91 | During a 1600 mile trip in my 1 ton the rear motor mount let go. every body sells a motor mount for the 1/2 ton but could not see a listing for a 1 ton. Are the motor mounts the same in 1/2 and 1 ton or not? Who knows where to find som which would fit? | | | | | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | Should be the same as a 3/4 ton..........We are talking about an AD truck, right? Most auto parts stores will carry stuff for 3/4 ton. Sometimes you have to order stuff for the bigger trucks........that's what makes them harder to restore/maintain. Hope you get it fixed; it's good to see you are cruising an old 1 ton
*** GMC ***
#2942 07/27/2003 12:51 AM | Joined: Jul 2002 Posts: 91 Member | | Member Joined: Jul 2002 Posts: 91 | yes it is a AD 1ton 1953. can't find anybody which has 3/4 or 1 ton motor mounts. Any body has any idea where whom to contact.
Will try to take the old one out and take some measurments to see what could be done | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | steele rubber products can rebuild your mount. | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | The Filling Station shows a mount in their catalog. 1939-53 GMC 1/2 to 2 ton, would that be the same
Regards, Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Jul 2002 Posts: 91 Member | | Member Joined: Jul 2002 Posts: 91 | Larry Thanks for the reply. Have to check that out on monday. I know the 1/2 ton is different. | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Just about any of the vendors have the mounts. I got mine through my local parts store, he had to order them.
Fred 52 3600 69 C-10
