| | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29374 08/12/2002 12:53 AM | Joined: Aug 2002 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2002 Posts: 30 | I have a '61 K10 truck with a 4 speed transmission - on the floor. Engine is the 235. I have two questions - since I've had the truck, the transmission grinds when shifting into 4th. It's never changed, better or worse, but it's always been there. If I double-clutch, it does not grind. What causes this? I've had this truck 15 years with the same behavior.
It has recently started popping out of third gear when not under load - like if I'm coasting down a hill in third gear.
Should I be worried about either issue? I'm running regular 80W-90 in the tranny and transfer case. Thanks in advance!!
1961 Chevrolet K10
#29375 08/12/2002 3:25 AM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | 4th gear grind is bad syncro. 3rd poping out probably is too. only issue is both are irritating. probably work that way for a long time. my 57 3spd had no syncros left when I got it [was previously an ambulance] and worked the same for another 30,000mi till I parked it for future resto. it poped out of third on the highway too. Bill  | | |
#29376 08/12/2002 4:34 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Nothing a rebuild kit wouldn`t hurt It may go on that way for a long time.
#29377 08/12/2002 12:12 PM | Joined: Apr 2002 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 146 | Mine did the same thing. The problem was excessive end play in the output shaft. You need to shim back to factory spec.
if it dosen't need fixed, break it
#29378 08/12/2002 3:30 PM | Joined: Aug 2002 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2002 Posts: 30 | Thanks for the info! It sounds like I'll be okay with the way it is for a while. In the meantime, I'll keep the fluids fresh and full.
1961 Chevrolet K10
