4 members (k2handyman, moparguy, dt235sd, Hotrod Lincoln), 71 guests, and 1 robot.
Topics128,049
Posts1,055,678
#29273 12/25/2002 10:27 PM
Does anyone know the actual weight of a GMC V-12.
I know it will run with power to only one coil and bank of cylinders eek grin cool I fired the beast up with hot wires to the coils.I forgot a return spring on the throttles(dual carbs)and it started to rev faster and faster really quick eek
I yanket the wires to the coils and only pulled one loose on the first yank.Left bank was still running and then I quickly yanked the second wire [img]http://pic4.picturetrail.com/VOL54/683118/1129406/17414310.jpg[/img]
http://pic4.picturetrail.com/VOL54/683118/1129406/17414375.jpg
http://pic4.picturetrail.com/VOL54/683118/1129406/17414294.jpg
#29274 12/26/2002 4:37 AM
V-12 powered GMC ND (New Design) 1/2 ton...
...MMM...more power....MMM...
I think we need bigger DONUTS on the back...
Think a souped up T-5 would handle it?!
That would be TOO COOL!! cool grin
Merry Christmas, Luke.
Regards,
Wannabe smile
"Don't expect anything and you'll never be disappointed"
#29275 12/26/2002 5:01 AM
Shipping weight from GMC was 1435 lbs. What you have there would be closer to 1500-1600 lbs.
So tell me a story about how you got this thing and what you think you mite do with it. It looks to be in better shape than my project motor.
[img]http://www.favorites.com/~jolly/roundup-12.jpg[/img]
Which I have mounted on a cut down horse trailer. More Photo of My Twin-Six Project can be found here.
#29276 12/26/2002 9:13 AM
Well, It runs really good(it does not want to stop!)
I am contemplating Putting it into a 2-ton truck and making a stovebolt retrieval vehicle.SOmething that can pull a fully buried truck out of the ground with a little torque to spare cool
It came out of a fire-truck which was getting a diesel engine installed.The fire-truck had documented 32,000 original miles.
This engine is COMPLETE from carburetors to starter to alternator and air compressor.It also has a transmission on it with linkages. I have not done a compression check on it yet but seems to run very smooth and no smoke other than what it burned out of the cylinders that I put into them.
When I went to get the unit, the guys who loaded it into my pick-up were thinking it was going to set my trucks frame down on the axles, they were a lot surprised(it didn`t even squat as much as I thought it would) grin
When it fired up, the whole house shook and the exhaust noise was a little loud eek (I stuffed rags in the exhaust after shutting it down to keep cold air from hitting the valves)
It sure put a smile on my face and made my heart beat a little faster cool grin
#29277 12/26/2002 9:38 AM
OK Now the light come on, your the one that e-mailed me about these mosters.
#29278 12/26/2002 9:50 AM
Yepper grin
What are you going to run with your project engine?
I noticed yours has the natural gas carbs where mine has the twin two-barrel gas carbs.
#29279 12/26/2002 11:30 PM
It would be nice to have a garage to work in, but I don't so IF I ever get my Twin-Six to run, it's needs one coil, and new wires, caps, points, well just a good old tune up, and then figure out how to or if propane will work with the carbs I have, or if I will be need to find and install Gas carbs, and then I still need to see if I can even turn it over by hand, I don't have a big enough brake bar at home.
I have it sitting on the trailer so the Rockford drive unit is on the back, and I'm thinking of building a tractor type PTO output shaft for it, then I could run the water pump at the lake or any of the other tractor powered equipment on the Farm here. If I find a genset of something like that than I would try running that with the engine. I know these things are Fuel Hogs, so putting it in a truck for daily use is out of the question. Back in the 60s I don't think fuel cost was an issue.
==========> End Of Line <==========
#29280 12/26/2002 11:43 PM
Turning it over with an 18in. 1/2in.drive breaker bar worked on mine.
The engine I have has a big 6 speed (I think) now removed.I think the tranny weighs around 250 to 300lbs itself. I am wondering if I can mate a Hydramatic to the rear of the engine(just curious)
Other thoughts were to see how difficult it would be to mount it in a 49 GMC 3/4 ton and drive it to Andy`s next August grin
