| | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29014 06/02/2003 12:34 AM | Joined: Nov 2000 Posts: 1,398 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,398 | Well I've only got about 10 miles on my truck since I got it back together and I admit there is some driver error here. I am after all still learning how to drive this old truck as it wasn't running before I started the renovation. As long as I double clutch on the up shift , most of the time it won't grind. If I don't double clutch it grinds bad. Down shifting can't be done without bad grinding. Nothing was done to the trans when the truck was apart other than a good cleaning and new gaskets and lube. It has a new clutch, throwout bearing and pressure plate. I have tried adjusting the clutch everyway possible and this is the best I can get it and it is all the way out. I'm wondering if I have a trans problem? | | |
#29015 06/02/2003 2:52 AM | Joined: Mar 2003 Posts: 10 Member | | Member Joined: Mar 2003 Posts: 10 | A non-synchro tranny takes practice. When downshifting it helps to give it a little gas when the clutch is in, to try to match gear speeds. There might be nothing wrong with your tranny. | | |
#29016 06/02/2003 5:32 AM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | as Sidehill sez, Bill - nothin wrong w/ the tranny cept age-ed design - the 46 4spd had no syncros, so ya need to double clutch up and down [or upshift veerrry slow] - takes some learnin to get it just right, but it can be done up or down w/ no grind [majority of the time!] - downshifting takes higher revs in the neutral step, upshifting, no gas]
Bill | | |
#29017 06/02/2003 11:28 AM | Joined: Nov 2000 Posts: 1,398 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,398 | Thanks guys for your responces. I will keep working on it. Gee, looks like I am going to have to spend a little more time behind the wheel! Nothing wrong with that. Thanks again, Bill. | | |
#29018 06/02/2003 5:28 PM | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | I find with mine on upshifts if I shift about the time it sounds like the engine has slowed to near idle rpm, it shifts without grinding. Doesn't seem to make much difference whether I double clutch or not. Down shifting, I usually double clutch and give the throttle a blip at the time the clutch is out in the neutral position. Still takes a lot of practice.
Harold Wilson 41 Chevy 3/4 Ton
