7 members (FishinToms53, Hotrod Lincoln, Rich'sToys, Stovebolt48, 50shep, Millenimech, mason86),
75
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#28927 03/18/2002 10:05 PM | Joined: Nov 2001 Posts: 31 Member | | Member Joined: Nov 2001 Posts: 31 | I just went to a tire place to get my tires taken off the wheels to refinish them. The problem is, my 3/4 ton wheels are 8 holes with split rims. It seems like a hassle to keep split rims since few places will easily or cheaply service them. So, is it a better option to buy new non split rim wheels? Thanks. | | |
#28928 03/18/2002 10:13 PM | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | I once had a 1951 1 ton GMC Stake Body truck that split rims. No one in town would touch them when I wanted to have new tires installed. I know that if a tire technician is not properly trained on how to mount and dis-mount a split style rim it can seperate under pressure and cause severe injuries. I saw a old tire ad that had a split rim in a cage like contraption while a tech was dis-mounting the tire from the wheel for safety purposes. I would think that one peice rims would be they way to go, maybe you can find a nice set of used ones to work with Phillip 1951 GMC 9300 Half ton Centreville Va
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | |
#28929 03/19/2002 1:19 AM | Joined: Jan 2002 Posts: 11 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2002 Posts: 11 | Check this link for info: http://www.stovebolt.com/bboard/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=4&t=000261&p= I finally stayed with my split rims. I like the look of the 3/4 ton hubcaps and a local tire shop that handles big trucks had no hassles with my split rims. Murph ...............___ _=======| :p \___ |(.....)_(O)____(....)c ...(O)...............(O) '49 GMC 3/4 | | |
#28930 03/19/2002 6:00 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | As I've said before, you have the two-piece lock-ring rim. Far safer to work on than the split rim. I have mine worked on at a tire shop that handles truck tires. $5 to dismount, $5 to mount is what I pay. My problem was getting 15" tires that were big enough. I wanted some mud grips in a 7.00-15 radial, only ones we could find were made in Taiwan. Am switching my rear wheels to 16", have installed the hubcap clips, finished painting yesterday. Will get some 7.50-16's mounted after the paint has cured. I bought two rims from a 91 for $40. And the inner part of the rim where the hubcap sits is the same size as the older rim.
Problems with this change is the front wheels. The setback (distance from the back side of the rim to the mounting face) is deeper on the newer wheels. This will cause the tires to hit the tie rod ends. I calculated an 1-1/4" spacer is needed to clear, too long for safety without overloading your lug bolts on the front axle. So I will run my stock 15s on the front and 16s on the rear for now.
Fred 52 3600 69 C-10
#28931 03/19/2002 5:04 PM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I found one-piece 16 inch 8-bolt rims which would fit the front of my 3/4T without hitting the tie-rod using 235-85-16 tires. They were 6 1/2 inches wide. I don't know what the set-back is (and can't tell you now since we're on the coast for a week w/o the '48.) One tire shop had those while the others had 7 inch wide rims which would not work. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#28932 03/20/2002 12:04 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Wally - Let us know. I assume those are aftermarket wheels? Also, the 7.50R16 is about an inch narrower than the 235-85R16.
#28933 03/20/2002 1:56 AM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Fred, I used 235-85R16's that were on my D**** 3/4T for a year. I also wanted them tall because the truck sat up high on the 7.00x17 tires that were on the truck when I got it. Are the 7.50-R16 tires as tall as the 235-85R16's?
I'll measure the set-back when I get to back to Montana. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#28934 03/20/2002 6:52 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | The 7.50 is .1 taller, .6 narrower. Not much of a difference really.
