Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (TexasFarmTruck, UtahYork, crenwelge, Mike1933, tclederman), 215 guests, and 6 robots.
Topics128,282
Posts1,058,496
Members48,490
#28851 11/03/2003 8:58 PM
After going over a good pot hole in my '59 3100 the Speedo started working again, but... the needle is erattic in that it swings 10 or 15 MPH.
Cable?, tranny gear, Speedo? any help would be great. I'm new to restoration but My Dad bought the truck new, I learned to drive in it, and I'll do what it takes to keep it on the road.
I know you believe you understand what you think I said, but I'm not sure that you realize that what you heard is not what I meant!
#28852 11/03/2003 9:20 PM
The cable needs white lithium grease. I found it in a spray can. It went in liquid and then turned to solid. Fixed a very nasty noisy cable in my case.
54 3100 with 235
62 flatbed dump C60 with 261
#28853 11/03/2003 9:20 PM
First thing to check is the cable. Disconnect at the tranny and you can pull the cable out of the housing. If it's frayed or twisted, replace it. If it's dry, grease it. I usually recommend the graphite based speedo cable grease, but you're far enough south to use a lithium or moly lube.
Fred
52 3600
69 C-10
#28854 11/03/2003 9:30 PM
Sounds good to me. Can you tell me where that pot hole is? I need to hit it about 100 times in my AD. cool
#28855 11/03/2003 9:49 PM
Thanks for your help guys! The pot hole is on the service road to I35E. It also fixed the left turn signal! Guess I'll be going through and tighting a lot of stuff.
#28856 11/04/2003 7:25 AM
I
Junior Member
Junior Member
I Offline
My 53 3/4 ton's spedo needle started jumping up and down 10 MPH or so..After changing the cable...then the housing and cable...then the lower gear I found the odometer drum in the head was sticking..Got a 64 Chevelle doing the same thing...It's odometer has quit all together.....
If all the cylinders ain't in a line it ain't cuttin it..
#28857 11/04/2003 10:21 PM
Just finished the Cable! It's all clean, shiney, and lubed up. The needle is rock steady.
Now to fix that gas gauge, I ran out of gas as I pulled intpo the driveway frown
