1 members (walterhvogel),
87
Mod | | | Forums66 Topics128,035 Posts1,055,559 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#28830 02/19/2003 5:22 AM | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | I have a leak from the steering box on a '41 that appears to be coming through the threads of the thrust bearing adjuster. It's dry everyplace but on the bottom where the locknut fastens the adjuster. It's more than just a drip, will make a puddle in a few days. Anyone seen this before and is there a fix for it? Someone suggested putting in chassis grease instead of steering gear lube, but I don't think that's a good idea. Thanks, HLW
Harold Wilson 41 Chevy 3/4 Ton
#28831 02/19/2003 6:41 AM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I put moly gear grease in all mine, Harold - works fine, just check it ocassionally.
Bill | | |
#28832 02/19/2003 6:43 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Done on UPS fleet vehicles  (the grease that is) I am wondering why it is leaking at that spot something does not sound right. Is there a crack in the cover that holds the adjuster nut?
#28833 02/19/2003 6:29 PM | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | Good idea, I'll take the locknut off this week-end and see if it's cracked, needs adjustment anyway. Soon as it leaks down a little more I'll add some moly grease. Thanks,HLW
#28834 02/19/2003 10:32 PM | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | The steering box rebuild kit that I did a few years ago had a small, GM booklet on the process. As I recall, the booklet recommended putting some Permatex gasket sealer on the threads before installing. I didn't (what, me follow directions :p ) and mine leaked there. Now that I am doing a frame off, I WILL seal those threads before I reinstall the steering box.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin "Always do right. This will gratify some people and astonish the rest." - Mark Twain
