1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#28753 07/03/2004 2:04 PM
Hi, I just replaced my ring gear and pinion in my 1954 Pickup and in the proccess to instal the axle shaft spacer. Manual tells me it has to give a maximum free fit of 0.14. I have 2 spacers available one gives a cleanrance of 0.06 and the other 0.18. Which one should I use?Thanks. Dutch
#28754 07/03/2004 11:05 PM
If it says MAX clearence , then you only have the option of the smaller clearence , that sounds ok.
