| | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#28753 07/03/2004 2:04 PM | Joined: Jan 2003 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2003 Posts: 33 | Hi, I just replaced my ring gear and pinion in my 1954 Pickup and in the proccess to instal the axle shaft spacer. Manual tells me it has to give a maximum free fit of 0.14. I have 2 spacers available one gives a cleanrance of 0.06 and the other 0.18. Which one should I use?Thanks. Dutch | | |
#28754 07/03/2004 11:05 PM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | If it says MAX clearence , then you only have the option of the smaller clearence , that sounds ok. | | |
