| | | Forums66 Topics128,037 Posts1,055,466 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#28289 10/28/2003 8:18 PM | Joined: Oct 2003 Posts: 11 Member | | Member Joined: Oct 2003 Posts: 11 | Hello everyone, I put a '58 235 in my brother's '50 3100. I used the shortened water pump and now the fan hits on the front of the crank pulley. I spaced the fan out about 1/8", using washers between the fan and the water pump pulley, but at moderate to higher rpm the fan still hits the crank pulley. I would like to space it out another 1/8-3/16" but really don't want to use that many washers. Does anyone know of a 1/4"-3/8" spacer that is made for use with the shortened water pump and pulley. Thanks | | |
#28290 10/28/2003 10:41 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Cut a shim out of sheet stock and stack them.
#28291 10/28/2003 11:30 PM | Joined: Jul 2000 Posts: 53 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 53 | Did you use the stock fan, or did you get an after market fan? How did all this sawdust get under the hood? | | |
#28292 10/29/2003 12:15 AM | Joined: Jun 2001 Posts: 169 'Bolter | | 'Bolter Joined: Jun 2001 Posts: 169 | BrianT,
I have the same problem and haven't found a solution yet. Hopefully someone will pipe up and shed some light on this.
I think you will have to space it out more than that to get it closer to the radiator for good cooling. Note that the fan sits much lower than the original 216 location.
Did you have any problem with the pulley hitting the front motor mount? | | |
#28293 10/29/2003 1:11 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The problem with 58-up engines and short water pumps in earlier vehicles is the radiator position. There isn't enough fan blade coverage of the radiator. I use a 2200 CFM electric fan in front of my radiator with a thermostatic switch, and it kept my 261 below 195 all summer, even at idle.
#28294 10/29/2003 2:56 AM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Expert on fan spacers here (though) I didn't choose to become one.
When you got the new shortened pump, didn't it come with a 1/4" steel spacer? All the ones I've seen do. If not you might contact who supplied the pump to you.
Another source is to contact fan mfg's such as flex-a-lite. I saw a spacer in a local pepboys store with their name (flex a lite). They were showing other spacers as well.
I bought this flex a lite aluminum spacer (1/2" thick) but it brought my fan within 1/16" of the rail of the lower radiator tank and since fan can flex forward a little when spinning, I thought this was a little too close. Thus I went back to my 1/4" spacer that came with the pump and pulley.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#28295 10/29/2003 4:09 AM | Joined: Jul 2000 Posts: 619 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 619 | I had the same problem with the 58 car 235 that I put in my 53, I just found some nuts that fit the screws that hold it on and put them between the fan and the pump, problem solved. Also I bought my pump from Carters and it didn't come with a spacer. MONGO | | |
#28296 10/29/2003 4:27 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | When I bought my short shaft water pump from Patrick's, I got a 1/4" spacer with the water pump. You might call patrick and ask him if he will sell you a 1/4" spacer or where you can get a 1/4" spacer.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#28297 10/29/2003 4:30 AM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | 6cyl, Thats where I got my pump. Good suggestion.
#28298 10/29/2003 7:07 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Take a chunk of 1/4 inch thick sheet steel and your w/p pulley. Mark the spots for the holes and the diameter you want your spacer. Cut it and drill it or have the machine shop cut and drill it for you if you cannot find the spacer from the vendor.
#28299 10/29/2003 9:43 AM | Joined: Mar 2003 Posts: 18 Member | | Member Joined: Mar 2003 Posts: 18 | not quite sure what you are spacing but the nose of the pump is necessary to center the fan blade not just the 3 or 4 holes around the pump. New aluminum pulley that do not have the snout protruding are not to be used with a mechanical fan. hope that helps Ed ke6bnl
1963 econoline, 50 f1 pu, maybe 53 chevy pu, 50 f3 pu, 70 chevy shortbed c10,
#28300 10/29/2003 5:34 PM | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | As someone said above, engine sits too low in relation to where the fan need to be. My answer to this question turned out to be an electric pusher fan in front and high up on the radiator.
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
#28301 10/29/2003 6:23 PM | Joined: Oct 2003 Posts: 11 Member | | Member Joined: Oct 2003 Posts: 11 | Thanks everyone for your responses. The first thing I told my brother after putting this engine in his truck, is that if he has any heat problems we'll go with an electric fan. For now though, I've run this combination a couple of times for 30 minutes or so and the heat never went above 170 after the 180 degree thermostat opened, so I'm not concerned yet with a heat problem. I did use the original fan. All after market fans and spacers I have seen so far have too small of a center hole for this combination. I realize I could use more washers and space the fan out and probably never have a problem, but I'd rather have a full spacer behind the fan. The suggestions about using round or square stock and a lathe are good , but I don't have a lathe and the machine shop will charge 40-$50.00 and hour to make one and I hate having $80.00 in a spacer. I've sent Patrick's an e-mail to see if they will sell just the spacer, I'll let you know. Yes, the crank pulley did hit the heat shield of the front motor mount. I just notched the shield enough so that it cleared. | | |
#28302 10/29/2003 7:02 PM | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Hot water circulates from the head thru the top rad hose down thru the radiator out the bottom into the block, therefor the fan needs to be up high, not down low. If you insist upon not moving the fan recommend using a 165 degree therm to get the 50/50 misture cooling sooner. You'll see what I mean when it gets hot again where you live.
#28303 10/29/2003 11:05 PM | Joined: Jun 2001 Posts: 169 'Bolter | | 'Bolter Joined: Jun 2001 Posts: 169 | "If you insist upon not moving the fan..."
Unless I don't understand the statement - you can't "move" the fan because it must connect to the water pump. If there is a heat problem you can only shroud or use electric as suggested.
My pump also came from Jim Carter without any spacer.
Chevy makes a smaller diameter front pulley/balancer that will clear the motor mount and drive a narrow belt - that's what I used.
PRW | | |
#28304 10/30/2003 5:11 AM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | My recent pump came from Patricks along with the infamous spacer. There's an outlet in So. Cal that has an interesting shroud that I might consider getting just to help direct the wind. I agree that for stop and go traffic, an electric fan might be the way to go. Possible project for next summer.....
#28305 10/30/2003 7:11 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | There is a pulley you can use the retains the stock 7" diameter and skinny belt but has the smaller dish of the short shaft pulley. It has the exact same bolt and center hole pattern. It is a fomoco part. I got it from a junkyard, for a dollar. I posted the part number on it some time ago and you can do a search if you are interested. It keeps the pump from cavitating and the fan from overspeeding. The pump I used is a stock pump that I pressed the hub down on and cut off the extra shaft. It has worked great.
#28306 10/30/2003 12:51 PM | Joined: Oct 2003 Posts: 11 Member | | Member Joined: Oct 2003 Posts: 11 | I called American CLassic, where I bought the pump, and they had no idea what I was talking about, (said I shouldn't need one). Patrick's said they send theirs out with their pumps, but I might check back in a week or so and see if they had any extra. Looks like I will be shimming it! | | |
#28307 10/30/2003 3:20 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | BrianT, As I posted earlier, I got a 1/2" aluminum spacer but will not be using it. If you think you need this much, I'd be happy to give it to you.
