4 members (Bill Hanlon, frogfarmer, 2 invisible), 346 guests, and 5 robots.
Topics128,156
Posts1,057,019
Members48,460
Apprentice
Apprentice
okay heres what i have so far. I have installed a booster and master(drum/drum) from a minnie winnie camper it had the perfect bracket to mount it on the
frame under the truck. The booster is used but the master is new its a 1 1/8" master. I have all new wheel cylinders and brake lines. I have no leaks I have bled and bled and adjusted and have NO brakes. 48bigtrucks i know you did a similar conversion. what am i missing. how important are residual valves
i dont know if my master has them. maybe they are the key. someone please help. thanks
I have no residual valves in my set up. Are you sure you adjusted both shoes at each wheel? Each shoe has an adjuster on the big trucks. Also, make sure the rod that pushes into the boost is adjusted properly. I had to make an adjustable one for mine. Sometimes these systems take a long time to bleed out. Is the master moving fluid? Is there a hydrovac in the system?
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Apprentice
Apprentice
Scott,
I have no hydrovac connected. i have the back wheels adjusted very tight. im gonna pull a drum back off and see if i missed something in there. im at my wits end. i cant figure it out. thanks for the
help.
Riding in the Passing Lane
Some of those had the rear wheel cylinders mounted at an angle. The air is not getting to the bleeder. You have to bleed it with them unbolted or put atiny screwdriver in the cup with the piston out.
1972 Chevy c10 Cheyenne Super
Apprentice
Apprentice
Okay to all those interested I think(that can be bad) That i have found my problems. the little pins that push the shoes. okay they are 5/16" shorter than the old ones. and im pretty sure thats enough to cause me a lot!!!!! of headaches. thanks for all the help ill let you know tomorrow the outcome as for now thanks. Chris
