4 members (HandyAndy, Jon G, 2 invisible),
148
Mod | | | Forums66 Topics128,087 Posts1,055,982 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#28221 01/10/2004 3:56 AM | Joined: Nov 2002 Posts: 4 Junior Member | | Junior Member Joined: Nov 2002 Posts: 4 | It's recently turned very cold. 327 engine started with ether in the carb, easily a couple days ago on seperate occasions. Been hard to start without a shot of ether. Truck does not run everyday, been used little recently. Today, after many attempts, it finally fired up for less than 10 seconds (running smooth), then shut down and could not restart even with the ether. Could the cold be affecting the fuel pump? Suggestions? How can I get good strong starts even with non-daily use, in winter too...thanks.
Brian Chaney
#28222 01/10/2004 4:04 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | This could be a lot of things. Water in the gas, bad fuel pump, fuel line blocked, fuel filter, carb problems or out of gas. First test is for fuel to the carb. Unhook the fuel line to the carb and stick it in a clean, dry clear bottle, like a pop bottle. Have someone crank the engine, you should get gas flowing. If it flows, and is clean, check the carb. If it's dirty, you need to drain the tank, clean the lines and the carb. If no fuel, does fuel flow from the tank, then to the pump.
Fred 52 3600 69 C-10
#28223 01/10/2004 9:58 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | What Fred T said,,,, when was the last time the plugs were changed? With all the cold moisture in the air lately I have had 4 cars I worked on have the very similar problem. changed the plugs with good ones and each vehicle started right up
