7 members (TexasFarmTruck, Otto Skorzeny, MOTOXFAMILY, Phak1, kurbside bolter, 2 invisible), 157 guests, and 3 robots.
Topics128,268
Posts1,058,378
Members48,485
#28124 05/09/2003 7:59 PM
I got the 3 spd back onto the engine of my '51 1/2 ton (the whole truck came in boxes), and have new synthetic 90wt filled up to the side plug level. There is another plug located near the rear of the housing that is almost on top of the trans. Does this need to be filled also? What lubes the u-jt in the torque tube? I know I should be able to figure this out myself, but the manual seems unclear...i appreciate having you guys available-Jim Smith
#28125 05/09/2003 9:17 PM
Yes, it needs to be filled with tranny lube too.
Paint & Body Shop moderator
