3 members (panic, 2-Ton, 1 invisible),
133
Mod | | | Forums66 Topics128,260 Posts1,058,343 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#28124 05/09/2003 7:59 PM | Joined: Dec 2002 Posts: 55 Member | | Member Joined: Dec 2002 Posts: 55 | I got the 3 spd back onto the engine of my '51 1/2 ton (the whole truck came in boxes), and have new synthetic 90wt filled up to the side plug level. There is another plug located near the rear of the housing that is almost on top of the trans. Does this need to be filled also? What lubes the u-jt in the torque tube? I know I should be able to figure this out myself, but the manual seems unclear...i appreciate having you guys available-Jim Smith | | |
#28125 05/09/2003 9:17 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Yes, it needs to be filled with tranny lube too.
