6 members (MNSmith, jfjbjr, Southerntruck, Gray_Ghost, Otto Skorzeny, wilbur53), 163 guests, and 1 robot.
Topics128,080
Posts1,056,062
Members48,433
#28076 11/10/2001 6:35 PM
I have a '53 235 in my '48 3/4T, still with the 4:57 rear-end. I'm pretty sure the engine is a full-pressure one from a car with an automatic (engine # LAQ 83376). The engine runs smooth as a top for my usual 3-5 mile trips around town every day. But when I take it out of town 10-15 miles at 40 MPH and really warm it up to the core, the idle speed increases and it seems to miss. It's kind of a fast slappity, bangity. When it cools down it goes back to normal. I haven't checked the timing when it enters this mode, but does it seem like a distributor problem?
#28077 11/11/2001 3:20 AM
You may want to check your heat riser valve to make sure it is not stuck. If the counter weight moves and the spring is there, you should be all right. Sounds to me like the heat riser is stuck in the shut (cold) position.
Remember 9-11-01--God Bless the USA
JUSTICE, not REVENGE, will prevail
1951 Chevy 1/2-ton Pickup truck
#28078 11/12/2001 8:15 AM
Check to make sure your valves aren't adjusted too tight, in addition to the manifold heat valve.
Paint & Body Shop moderator
#28079 11/12/2001 11:56 AM
Anonymous
Unregistered
Anonymous
Unregistered
Also check that the intake is not sucking air after warm up. Common on a 235.spray some carb cleaner around the intake to head and around the carb base. CAUTION this can produce fire so dont use a whole can. Maybe retorque the intake(most times if its leaking its to late) I have also seen about 3 -4 warped 235 intakes that i had to cut.Check the carb gasket also and make sure the carb is tight.
#28080 11/12/2001 6:29 PM
I freed up the heat riser valve a bit. Should you be able to turn it with your fingers?
I'll use a little bit of carb cleaner around the intake manifold ports when cold and then hot. I will wait for one squirt to evaporate before hitting the next intake port.
#28081 11/13/2001 8:50 PM
V
V Offline
Wally - do the tune up thing , ALL of it , then follow the directions everyone recommended . I had and old Chevy 6 - banger that had a collapsed piston skirt - it slapped and banged terribly when fully warmed up and burned quite a bit of oil too - ran like that for years and years , keeping it properly tuned , of course .
-Nate
There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
Also, that dooflinkie spacer that you should have betwixt the "rot pot" and the manifold to keep the gas from overheating(vaporlock and all that)should be secure and tight, some guys use gaskets on both sides, as I have, the manual says its not needed, and we can all fight about that until the next war, but I noticed a HUGE difference in fuel milage after sealing it with bathtub sealer, some paint to make it pretty, two hail Marys and some salt thrown over my back for good measure.As far as piston slap goes, after a minute or 2, it should be gone. I have a 409 that has horrendous slap when cold,as these motors are known for and as scary as it sounds, theres no problems,Chevy dealt with this issue late '62, but my '65 "nine" still sounds like a box of rocks when cold.
Hmm.. I had a friend who told med that the damned heat riser valve was not needed if you only drive it in the summer time.
So he removed it when he fixed a big crack in the manifold.
And of course I should have sealed off the intake from the exhaust with a thin plate or something. Now I guess I will end up with the same thing when it gets hot. =(
My Chevy Viking 1959
Ulf Hedlund. Eskilstuna. Sweden
[email protected]
Also:
Ford Galaxie 4 dr 1959
Ford Custom 4 dr 1964
Ford Mustang GT 2005
ok on the heat riser, which is open up or down?
J Online: Content
The weight pulls it closed. spring opens it so heat goes up.
Joe
ODSS Lawman
ODSS Lawman
Wally
It sounds like the engine was tuned before it got to full operating temperature. When the engine gets fully warmed, many items expand and when this happens, things run differently.
Perform all the tune-up tasks, just get the engine good and warm first.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Denny G
Sandwich, IL
Do you recent posters realize that this is a very old post "revived" by a jerk, ELKAYE, who has done this with several other posts over the past few days? He must be having a good time wasting everyone's time.
He should be warned and/or kicked off the discussion board.
#758342 06/28/2011 11:44 PM
Forget the warning- - - -find a tall tree and a short rope!
:mad: :mad: :mad:
Be nice, he is just a wayward newbie
