0 members (), 153 guests, and 1 robot.
Topics128,110
Posts1,056,241
Members48,437
#2788 01/08/2003 3:50 AM
Hi everyone. I have a '52 Chevy with M II front suspension, and I would like to keep the original column and steering wheel. Does anyone have any sugestions about the best way to do this? Can I just cut it off and weld on a u-joint? I seem to remember someone talking about this awhile back, but I can't find it.
Chevy Duty made up a kit to keep the stock column when connecting up to their power steering kit "I think they use the newer 70-80's box that mounts on the outside of the frame" Part # 76-985A .
Your basically going to need a lower support bearing to support the inner shaft at the lower part of the column. Couldn't you just use an Upper mast bearing on the bottom to support the inner shaft? You'll still to make a bracket to secure the bottom of the column to the toe board, two Borgeson joints and a coupler shaft to make the connection from the column to the Mustang rack.
Joe
I did it. It's working fine as frog hair.
http://www.chuckthetruck.homestead.com/page11.html
At the bottom.
Thanks guys. I've got it now.
For those interested, RB's Obsolete sells what they call Save-a-Column designed as a unit to retain an original Column and Steering wheel and connect to other shafts.
JohnRJoyner
48 Suburban,55 1st 1/2 ton, 53 GMC
