2 members (John Dlugos, 1 invisible),
150
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 12 New Guy | | New Guy Joined: Nov 2001 Posts: 12 | Hi everyone. I have a '52 Chevy with M II front suspension, and I would like to keep the original column and steering wheel. Does anyone have any sugestions about the best way to do this? Can I just cut it off and weld on a u-joint? I seem to remember someone talking about this awhile back, but I can't find it. | | | | | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | Chevy Duty made up a kit to keep the stock column when connecting up to their power steering kit "I think they use the newer 70-80's box that mounts on the outside of the frame" Part # 76-985A .
Your basically going to need a lower support bearing to support the inner shaft at the lower part of the column. Couldn't you just use an Upper mast bearing on the bottom to support the inner shaft? You'll still to make a bracket to secure the bottom of the column to the toe board, two Borgeson joints and a coupler shaft to make the connection from the column to the Mustang rack.
Joe
| | | | | Joined: Nov 2001 Posts: 12 New Guy | | New Guy Joined: Nov 2001 Posts: 12 | Thanks guys. I've got it now. | | | | | Joined: Jan 2002 Posts: 19 New Guy | | New Guy Joined: Jan 2002 Posts: 19 | For those interested, RB's Obsolete sells what they call Save-a-Column designed as a unit to retain an original Column and Steering wheel and connect to other shafts.
JohnRJoyner 48 Suburban,55 1st 1/2 ton, 53 GMC
