0 members (),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#27849 02/12/2002 5:15 AM | Joined: Mar 2000 Posts: 11 Junior Member | | Junior Member Joined: Mar 2000 Posts: 11 | :confused: I have a 1934 chevy with a 207c.i. motor. The drive gear on the distributor is worn enough that I feel it will affect the timming. I have be unable to locate a new gear and pin or a rebuilt distributor, so my question is. What year vehicles distributor will fit my application? Or am I stuck trying to locate a gear for my original unit? | | |
#27850 02/13/2002 2:11 AM | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | From 1933-early 35, my literature says they usd model 644-R distributors, part # 1853759. Not used any other years. I assume that the engine is stock, I know very little (i.e., nothing) about those early vehicles. | | |
#27851 02/13/2002 3:09 AM | Joined: Mar 2000 Posts: 11 Junior Member | | Junior Member Joined: Mar 2000 Posts: 11 | You are correct the number on the distributor is 944-R. The engine is stock. I am trying my best to restore the truck as close to original as possible. But, it has taking me three years and two motors to come up with a rolling chassis. Not sure I am going the correct route? thanks | | |
#27852 02/13/2002 4:55 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The Chev parts book says that gear fits 29-36 all.
See the USA in your vintage Chevrolet! My Blog | | |
#27853 02/15/2002 3:25 AM | Joined: Nov 2000 Posts: 45 Member | | Member Joined: Nov 2000 Posts: 45 | If the local parts places can't get you a new gear, then try looking at Hemmings Motor News. Several vendors in there that specialize in early Chevies. | | |
