| | | Forums66 Topics128,087 Posts1,056,114 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#27827 11/06/2002 11:22 PM | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Can someone tell me the GM part # for a 1960 hydraulic lifter for a 235? Is the part # the same for the 54-58 and the 59-62 Hydraulic lifter for the 235? Are the hydraulic lifters for the 235 and the 261 identical? | | |
#27828 11/09/2002 5:17 AM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | This new guy sure got a lotta answers.
54 3100 with 235 62 flatbed dump C60 with 261
#27829 11/09/2002 4:52 PM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Rusty, I bought hydraulic lifters for my '53 235 before I knew I was switching to a '61 261. The US truck 261's came with solid lifters even though they were drilled for hydraulics (check your block) The Canadian Pontiac 261's had hydraulics. It's my understanding that my 235 lifters would fit my 261. What gives me concern is NAPA had two different part #'s for the 235 and 261 hydraulics. I'll think I'll do an exchange. Check out Jim Carter's piece on the 261 if you haven't already read it. http://www.oldchevytrucks.com/cgi-bin/htmlos.cgi/00900.2.2276781697922088411 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#27830 11/09/2002 5:13 PM | Joined: Jun 2001 Posts: 169 'Bolter | | 'Bolter Joined: Jun 2001 Posts: 169 | Have you folks priced solid lifters for the 235 lately! Parts America was $22 ea. and NAPA was $20 each with Clifford cams coming in at $130/set. Needless to say, I was shocked and ended up buying from Patricks for $70/set of 12.
PRW | | |
#27831 11/09/2002 6:16 PM | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | Rusty46
Here's the '59 parts book stuff on 235 lifters.
41-55 ALL (235) (exc. P.G.).......................w/rod seat (yellow paint under rod seat) p/n 3660438
53 PASS. w/P.G.................................... hydraulic type (3 holes on side) (HL-17) p/n 5230850
54-55 PASS. w/P.G. (6 cyl.), 56-58 PASS. (6 cyl.) (exc. '58 TAXI)........... hydraulic type (1 hole 1/8") (HL-18)....... p/n 5231450
58 TAXI w/3752735 cam (6 cyl.), 59 PASS. (6 cyl.).................................. hydraulic type (HL-31)............................ p/n 5231830
The only 261 listings are mechanical (book only goes thru '59')
54-55 UTIL. (261)..................... mechanical type, single groove around body......... p/n 3836342 56-59 Ser. 3-4-6 (6 cyl.)........... mechanical type...................................................... p/n 5231800
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
#27832 11/09/2002 6:17 PM | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Hi Guys Thanks for your help. I have a 60 261 short block and a 55 848 head. I have really appreciated the thread started by Stingray regarding block and head oiling. Thank you Chip for being so persistent with your questions. I also need the rocker arm oiler/connector if you find two. Thank you Tony and Olblue for your in debth research regarding 235 261 engine oiling and interchangeability. I hope the meat of that thread is preserved for others to come. Now I'm dealing with the hydralic lifters. I've also found 2 part #'s for the hydralic lifters. How about it Tony? Olblue? Somebody must have some part #'s for these lifters to determine interchangeability/application. Help please.
Regards to all, John | | |
#27833 11/09/2002 6:42 PM | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | OlBlue et al Do you have an application for hydraulic lifter part # 5230920 ? Thank you for your help!
John | | |
#27834 11/09/2002 6:59 PM | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | Rusty46,
No joy on that number in the books I have.
#27835 11/09/2002 7:23 PM | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Thanks OlBlue I appreciate the lookumup | | |
