2 members (baldeagle, Hotrod Lincoln), 110 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#27769 02/28/2005 1:53 AM
Junior Member
Junior Member
I'm in the process of restoring my '55 1st series 1/2 ton p/u. What was the original engine/bell housing/transmission (3 spd manual) color?
#27770 03/01/2005 5:27 AM
I know the 235 was blue in the Chevy cars starting in 54, and I think the trucks used this color too. The bellhousing and transmission I'm not sure. The transmissions may not have even been painted, left their natural cast iron color. They do make a cast iron paint that is very nice.
#27771 03/01/2005 12:04 PM
Donald: first let me welcome you to the Stovebolt pages. You'll find a great deal of information and some entertainment here.
Secondly if you'll use the Search feature found here you will see that this question has been discussed at length and I'm certain your answer is there. Again, Welcome.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#27772 03/02/2005 5:16 AM
Donald D,
You haved made your entry with a time-honored question. Here is a pretty good compilation of Chevy engine colors: http://www.danroy.com/ Go to this link and scroll down to Tailgate eTalk.
My bet is that 1954 and newer car 235 engines were blue (of "Blue Flame 6" fame) and truck 235 engines were gray (but the 1960 and upwards 235 trucks' supposed blue-gray color is real pretty).
My guess is that the bell housing and transmission were "natural".
This topic is a lot like religion - it takes faith to truly believe what you think you know (and, be careful questionning other peoples' faith).
Tim
#27773 03/02/2005 1:22 PM
Tim, that link is not working for me...
Andrew
A man is like an old truck... He will rust out before he wears out...
#27774 03/02/2005 3:18 PM
Andrew,
That link did not work for me this morning on my office machine. I have changed the link above and it should now work - but, you might have to try it a couple of times (after I have cleared my browser's cache I have trouble loading the link on the first try). Once the link is in my brower's cache, I can bookmark it and have no problem going to it. Maybe someone can explain this phenomenon.
Tim
