| | | Forums66 Topics128,266 Posts1,058,367 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#27752 04/10/2002 4:56 AM | Joined: Jan 2001 Posts: 12 Member | | Member Joined: Jan 2001 Posts: 12 | Can anyone tell me the difference between water pumps for a 292 versus the 230&250 engines? Know of a company making a performance pump for the 292?
'64 C10-292 with TBI, 4speed, 3.42 rear
#27753 04/12/2002 6:17 PM | Joined: Dec 2001 Posts: 146 Member | | Member Joined: Dec 2001 Posts: 146 | eb1,
As far as I know, at least here the 235/250 and the 292 can use the same pump. The diff is that as the 292 only saw duty here as a truck engine(no pick up's) and the 250 is normally a pass car or light truck engine, the water pump varies just because of that, but the mounting pad is just the same. Same for gas pump, distributor, manifolds and cilinder head. Even the gaskets are the same.
Alexandre Garcia
#27754 04/13/2002 12:58 AM | Joined: Nov 2001 Posts: 72 Member | | Member Joined: Nov 2001 Posts: 72 | The 292 pump is different. You can physically use the 250 but will have problems. Check Cliffords web site and do a search. Lots of good stuff. Hope this helps Dennis | | |
