7 members (eclector, 32Fordpuchoptop, Hotrod Lincoln, dt235sd, MickeyP, 2 invisible), 154 guests, and 1 robot.
Topics128,033
Posts1,055,531
Members48,425
#27752 04/10/2002 4:56 AM
eb1
Offline
Can anyone tell me the difference between water pumps for a 292 versus the 230&250 engines? Know of a company making a performance pump for the 292?
'64 C10-292 with TBI, 4speed, 3.42 rear
#27753 04/12/2002 6:17 PM
eb1,
As far as I know, at least here the 235/250 and the 292 can use the same pump. The diff is that as the 292 only saw duty here as a truck engine(no pick up's) and the 250 is normally a pass car or light truck engine, the water pump varies just because of that, but the mounting pad is just the same. Same for gas pump, distributor, manifolds and cilinder head. Even the gaskets are the same.
Alexandre Garcia
#27754 04/13/2002 12:58 AM
The 292 pump is different. You can physically use the 250 but will have problems. Check Cliffords web site and do a search. Lots of good stuff.
Hope this helps
Dennis
