2 members (FishinToms53, tesa),
107
Mod | | | Forums66 Topics128,087 Posts1,056,000 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#27672 03/16/2004 4:06 PM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | Can anyone help me with the applications for GM #3748437 ring and pinion set? Box says 57-58 with automatic. I need to know if this will be for a car or truck differential. I looked in my '46-'72 Chevrolet truck Master Parts Manual but could not find it. Thanks for any help with this.  | | |
#27673 03/17/2004 4:11 AM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Where is this number stamped or casted?
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#27674 03/17/2004 5:40 AM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | I don't have the gear set in my hand, because I don't know if they would work in a '55 first series differential housing. That is the number on the box. Parts Manual I have states they were sold as a matched set same number for both ring and pinion. I had heard of a truck fuel saver option ratio offered in '58, but lack any more information or part number for it. Patrick's now offers a 3.38 set for '55 and up trucks, around $400. I have a price for this nos set a lot less. But will they work???? :confused: | | |
#27675 03/17/2004 7:43 PM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | If anyone out there has one of those rare late '50s Master Parts Manuals, this part number would be listed in 5.529 Gear Assy.. | | |
#27676 03/17/2004 9:31 PM | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | My Master Parts Book covers through 57. No number that high for ring & pinion. | | |
#27677 03/17/2004 11:15 PM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | I sure wish I could get a second opinion from a '59 book. The application would cover 55-59 differential housings in the half ton. Thanks for looking. :confused: | | |
#27678 03/18/2004 12:05 AM | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | I have all these Factory Chevrolet Service News Bullitins that were give out to the factory mechanic and this is what it say's about the rearend gears for the 58 truck. "Series 31 and 32 carry the 3.90:1 axle ration of previous models as standard equipment. An Optional axle of 3.70:1 is now available" Is this the fuel saver option??
I looked in my Interchange Manual and thought that I found that number you indicated but it's one number shy. I found 3748436 which is for a 53-55 3.55:1 gears in a Corvette and sold for a sum of $46.95
Joe
#27679 03/18/2004 1:21 AM | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | I looked a little more in my Interchange Manual and found the 3748437 gears are a 3.36 Ratio and go to the 56 Corvette although they will interchange with the other 50-62 Vette's by using the case. I don't see that number 3748437 crossing over to work in the truck rearend.
Joe
#27680 03/18/2004 1:34 AM | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | that rear end could be worth somthing to sombody restoring a corvett | | |
#27681 03/18/2004 2:01 AM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | Thanks for the help on this! I had suspected they were probably for a 'vette. They did not sell or meet the reserve price around $125. Since Patrick now sells 3.38 gears for the 55-59 trucks, I thought these might work. I'll be happy to pass on the information to anyone who may need them.  | | |
#27682 03/18/2004 2:30 AM | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | Your very welcome for the help. Thanks for the question, it gave me a reason to open up the Interchange Manual my Uncle gave me as well as the binder of Chevrolet Factory Service News Bulletins I purchased at an estate sale for a $1.
Joe
#27683 03/18/2004 3:04 AM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | Hay, while you got the BOOK handy, does it show anything taller than 3.90 for the 1/2 ton '55-59? | | |
#27684 03/18/2004 5:32 AM | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | Here is what the book shows for gear ratio's
For GM Built H0333 Axle A) 3764960......3.36 Ratio 3749020......3.70 Ratio 3747808......3.90 Ratio Chev Tr 55-5u 1/2 T Conv Chev Tr 58-59 1/2 T Conv Non-Locking Axle Chev Tr 60-62 10 Series (1/2T Conv) GMC 55-56 (Y,X) 1/2 T Conv
B) 3747809......4.11 Ratio Chev Tr 55-57 1/2 T Conv Chev Tr 60-62 10 Ser (1/2 T Conv) .............................................. For Spicer 45 Axle
2354371.....3.92 Ratio Chev 58-59 1/2 T Conv Locking Axle GMC 56-59 (X,T,S) 1/2 T Conv
Joe
#27685 03/18/2004 6:30 AM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | seems like that 3.36 [or the 3.38 around nowadays] would need a/the 4 speed to be really usefull - what's the ratios on the 3spd and where does one find the ratios of the saginaw 4spd? [Tony?]
Bill | | |
#27686 03/18/2004 7:13 PM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | Patrick Dykes has a rundown on this he put together for uses of the 3.55 ring and pinion. No doubt he now has one for his 3.38 set as well.  | | |
