| | | Forums66 Topics128,081 Posts1,055,959 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#27572 12/07/2003 12:38 AM | Joined: May 2003 Posts: 111 Member | | Member Joined: May 2003 Posts: 111 | I know it's been asked but I can't find the thread, so here it is again: What 5 speed trannys can be used with a 68 250? Easiest bolt up/conversion. I know that I'll have to change the driveshaft (I hate 2 piece shafts anyway, just gives a second spot for pole vaulting), but what else? I do a lot of driving (long range fishin spots) and the mileage increase would be nice. Secondary question, I'm considering finding an old 327 to rebuild in the garage. Would the 5 spd still bolt up?
35 + years of rollin' steel!
#27573 12/07/2003 3:00 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | 327 and your 250 would use the same bellhousing, so if you mount the motor in the stock location it should bolt up the same.
Putting an S-10 5-speed behind a 235 requires playing some games with the clutch, but I think that part would be easier on a 250 or 327. But I've not done it, so I don't know all the details.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#27574 12/07/2003 5:03 AM | Joined: Jul 2003 Posts: 55 Member | | Member Joined: Jul 2003 Posts: 55 | Go to www.inliners.org Look on the left side...click on "Tech Tips"...then scroll down to "T-5 Tranny Swap" They also have some links on there to this site, and others. http://www.inliners.org./ubb/Forum2/HTML/000358.html Most likely you'll want to get a T-5 from a Camaro/ Firebird application, because of the better overdrive, gear spacing, and first gear ratio. You'll have to swap another tailshaft onto it. That is unless you don't have a bench seat, or you have room for a shifter that is further back. I'm wanting to do this swap, but I don't have the money or time right now. The only problem seems to be the clutch package, which various people have found ways to solve. Email me if you want to chat, or if you need more info. As far as the 327 goes, it would depend on how beefy you build the engine. If it's a completely stock (really mild) 327 it should hold up to the power. The T-5 trannies aren't that strong. Hope this helps. John [email protected]
1968 Chevy C-10, 250 and 3 speed on floor, Hedman headers, Offy intake, Edelbrock 600cfm 4 barrel, HEI 1966 Chevy C-10, motor and tranny went into the '68. Waiting to be restored.
