2 members (Steveoreno, TPR57C),
106
Mod | | | Forums66 Topics128,186 Posts1,057,320 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#27557 04/23/2005 11:28 PM | Joined: Apr 2005 Posts: 3 Junior Member | | Junior Member Joined: Apr 2005 Posts: 3 | Hi All, I'm new here so please be gentle. I realize that a '59 El Camino technically isn't a truck, but it happens to have a 292 swapped into it. The oil pan is trashed and I am not sure what my options are. The block code (3851659) says the engine is a '63-'76 292 and it has a rear sump. Are all of the pans for the 292 the same or are there different versions? Are the same as the 250? I would glady buy a new one if available, but I need to know what to look for and where. Any help would be greatly appreciated. Thank You, Gene
Gettin' Old Aint For Sissies
#27558 04/24/2005 7:05 PM | Joined: Oct 2002 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 77 | Gene the 292 oil pan is deeper than a 250 pan but can be used if you change the pick-up tube from the 250, as far as the 292 pan all beening the same all of them I have run across have been. | | |
