5 members (UtahYork, klhansen, Rich'sToys, Millenimech, Wayne67vert), 181 guests, and 1 robot.
Topics128,182
Posts1,057,260
Members48,467
#27557 04/23/2005 11:28 PM
Junior Member
Junior Member
Hi All,
I'm new here so please be gentle. I realize that a '59 El Camino technically isn't a truck, but it happens to have a 292 swapped into it. The oil pan is trashed and I am not sure what my options are. The block code (3851659) says the engine is a '63-'76 292 and it has a rear sump. Are all of the pans for the 292 the same or are there different versions? Are the same as the 250? I would glady buy a new one if available, but I need to know what to look for and where. Any help would be greatly appreciated.
Thank You,
Gene
Gettin' Old Aint For Sissies
Gene the 292 oil pan is deeper than a 250 pan but can be used if you change the pick-up tube from the 250, as far as the 292 pan all beening the same all of them I have run across have been.
