2 members (Gdads51, Jon G), 100 guests, and 0 robots.
Topics128,049
Posts1,055,691
#2724 12/23/2002 9:55 PM
I have a 54 3100 1/2 ton that someone before me took out every piece of the parking brake assembly. I would like to know if anyone has done a retrofit or if there is a universal type parking brake I could use rather than try to piece a stock one back togather. I also have a 84 trans am disc brake rear end in her. Thanks in advance. Awesome site and helpful tips.
#2725 12/24/2002 2:22 AM
smile howziit bob!
Hmmm, i'm in the EXACT same boat as you, except with a 9" rear...and my safety inspection is due next month. frown
JMO, the simplest/most logical solution is LOKAR everything, from floor-mounted emergency brake($70), to complete cable assembly($79), from brake handle to rear brake shoes.
of course, hard-headed me, in order to keep the floor clear, is trying to locate either a 1997 Saab(swedish car) brake handle, or a chevy vega brake handle...onto the ledge, between the driver's door, and the seat.
for me, the original hand brake is not an option, because of the camaro subframe, and because every piece of the handbrake system was eliminated...just like yours.
FWIW, if i have too much difficulty installing the side-mounted brake handle and cables, i'll go for the tried-and-true LOKAR system...on the floor.
Myron
1956 chevy 3100 stepside, Pro-Street stance, mild 454 BBC/350/9"/13" M/T'S, daily driver, aka THE PINK LADY
1957 Bel-Air coupe, 500 HP blown sbc in progress, aka LANI
#2726 12/24/2002 2:37 AM
Anonymous
Unregistered
Anonymous
Unregistered
I grabbed a standard GM suspended E-brake operator and cable from a 70's? chevy car (chevelle laguna) and bolted it to the inner cowl / firewall / dash right where the old e-brake was removed from. Re-used the original E-brake handle and lower dash bracket to retain somewhat of a stock look. Set it up just like a camaro/firebird as I was using a firebird rearend.
#2727 12/24/2002 4:57 PM
Thanks for all the help. I didn't know the lokar was was that inexpensive. I'll probably go that rout. thanks again.
#2728 12/24/2002 5:54 PM
Quote
smile howziit again Bob!
that price quote was from www.summitracing.com
with the 10% discount included, if you order by dec 31st.
you need to order more than $299.00, to qualify.
mention M26100 for that 10% off retail price.
Myron
#2729 12/24/2002 6:15 PM
Hey Bullnose, Welcome to The 'Bolt. When you get done this project, could you post and let us know how it works out? I've got a '79 T/A rearend with discs waiting for its AD, so I'm curious just how it'll all go together. TIA.
Hope you have a good holiday season.
Regards,
Wannabe smile
"Don't expect anything and you'll never be disappointed"
