| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#27199 04/03/2004 5:00 AM | Joined: May 2003 Posts: 213 'Bolter | | 'Bolter Joined: May 2003 Posts: 213 | I talked to a guy with a nice frame to sell for a 53 3100. It's been blasted and primed and looks pretty good.
He's wondering if there is any ID (serial #) on the frame and if there would be any trouble if he sold the frame to someone who put a different #'d body on it.
Any advice I can relay to him? | | |
#27200 04/03/2004 5:40 PM | Joined: Sep 2002 Posts: 115 Member | | Member Joined: Sep 2002 Posts: 115 | According to "Vehicle Identification 1938-1968" which is the publication used by law enforcement and motor vehicle departments to find ID numbers, there should be no number relating to vehicle identification on Chevy truck frames from '38 through '53 (probably earlier, too, but this book starts with '38). In '54-'59 the serial number was stamped on top of the left frame rail halfway between the front of the frame and the firewall. It might be a good idea to look there to make sure it wasn't a really late '53 frame, or a misidentified '54 frame, just in case.
If 'twere me, I'd be sure that the body comes with a clear title and a proper matching number plate on the door hinge pillar, and not worry about a possible frame number. It's covered up by the fenderwells, and the DMV people are looking for the body plate anyway. Unless there is suspicion of stolen parts or a stolen truck, usually caused by title documents that don't match the body number, they'll never look for a number on the frame, especially when the book says there isn't one.
And make sure that any title issues are resolved *before* spending any serious money or doing a lot of work. I heard a story just the other day about a local guy who spent a couple of years and a bunch of money on an F-100, only to find out he couldn't get title because the truck had been involved in a messy divorce before he got it. He ended up getting things straightened out (in a devious manner) but it was a lot of trouble.
Another reason to get title resolved before starting work, at least in CA, is that CA charges tax on the value of the vehicle. Before you start work on it, it's worth a lot less, and your title documents will reflect that value as long as you own it. Technically, you're supposed to go to the DMV and fill out a form that says you have done work that increased the value of the vehicle by X dollars, so that you may have the privilege of paying more taxes, but I've never heard of anybody actually doing that and I've never heard of anybody being challenged on it.
It's a lot harder to set a low value when the DMV clerk has just done a VIN verification on a restored truck that still smells like new paint. Some of the DMV people are ignorant, but few are stupid. If you go in to take care of title and registration after you build the truck, your renewal will reflect that every year.
Joe (who used to be an independent licensed VIN Verifier for CA DMV) | | |
#27201 04/05/2004 2:54 AM | Joined: Mar 2004 Posts: 313 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 313 | SInce you guys are on the subject of vehicle numbers, I'd like to ask a question. Many people swap engines in the 47-54 Chevy trucks. And in those years, at least around here, the DMV (known as Dept. of Revenue here) used the engine number to I.D. the vehicle. What happens when a person goes to tag the truck after the swap, and the title shows the original engine number? I didn't think I would have any problem, because I had always heard that there was an I.D. number stamped on the frame. I was sorta hoping to be able to show that number to the Highway Patrol if there was any problems at inspection station.
1953 3100 with 1957 235, T5 and 12 bolt 373 rear
#27202 04/07/2004 4:17 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Joe, I don't want to argue with you but I believe the book is wrong. I have my '54 GMC frame bare getting it ready for the sandblaster. There is no number anywhere near where you mention. I also checked a '55 early Chevy and a '55 second GMC. No numbers. The numbers are there on my '59 1 ton. | | |
#27203 04/07/2004 4:35 AM | Joined: Sep 2002 Posts: 115 Member | | Member Joined: Sep 2002 Posts: 115 | Cletis, that doesn't surprise me at all. I wouldn't bet any of my own money on any one statement from the book, but as I recall from when I was doing verifications, the books were pretty accurate.
Not that it matters any more, but I've made notes in my copy of your findings.
Thanks. | | |
