0 members (), 140 guests, and 0 robots.
Topics128,260
Posts1,058,343
Members48,485
#27098 06/01/2003 9:57 PM
Apprentice
Apprentice
Hi, I've got a 235 with a vacuum leak. The governor under the Carter W-3 carb has been fingered as a prime suspect. Any reason I shouldn't remove it?
Another thing - I don't know the year of this 235; it's not original, but did they ever come with Carter W-3's? If I want to swap it, what should I replace it with?
Any suggestions appreciated.
Dave '47 One Ton
Don't read the directions, that'd be too easy.
#27099 06/01/2003 10:16 PM
I removed the gov. from my 261. No problems and removed a source of a vacumm leak. Just don't over rev the engine. I replaced my Carter with a 2bbl. Holley/Weber mounted on an adapter. Has been working fine for 6300 miles now.
#27100 06/01/2003 10:27 PM
Dave I've taken govenors off engines myself but I'am the one that drove it and did not over rev it. You can change the studs or make a spacer that the same thickness as the governor, you may find one that works.You can find the year your motor was built on Inliners International.Dave H
#27101 06/03/2003 1:52 AM
Apprentice
Apprentice
Thanks for the help. Are spacers in place of the governor a part that is sold, or do you have to make one? Also what number on the block do I look for to determine the year of the engine? The serial no. is FEA 42033 and doesn't correspond to any numbers on the Inliners page.
Thanks again. Dave
