7 members (Ponchogl, Otto Skorzeny, moparguy, KEVINSKI, Brian Moore, 55shaker, ShopRag),
71
Mod | | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#27067 11/11/2003 2:39 AM | Joined: Apr 2000 Posts: 179 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 179 |
Joe McNeel
http://mcneelnet.com/~jmcneel/59.html
#27068 11/11/2003 3:05 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I once had one. It worked just fine, but when the power steering pump failed I pulled out the entire motor and installed a V-8...
I sold mine to a guy who thought it would be cool in his Chevy II.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#27069 11/11/2003 3:08 AM | Joined: Oct 2003 Posts: 6 Member | | Member Joined: Oct 2003 Posts: 6 | I would have thought that the le mans was worth more with that mortor still in it ? I had a freind with one years ago and for a 6 it moved . | | |
#27070 11/11/2003 3:29 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Yet another "don't ask questions I can't answer" Ebayer
The poncho "sprint 6s" were put into lemans and firebirds in the late 60s. There was also a 4bbl option available, with 250 or so HP. Only prob is that the timing belt and upper timing pulley had a problem with breaking. Or so I was told by a coworker, who pulled the one from his 66 lemans to drop in a 389 GTO mill.
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#27071 11/11/2003 5:03 PM | Joined: Feb 2001 Posts: 164 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 164 | Boy that would look great with 3 side draft SU carbs mounted on a clean log manifold....... Hmmmmm...
My vague shaky memory seems to reinforce the timing belt problems on these motors. Of course GM has had to take more than one shot at some things over the years to get it right.....
Cheers.... | | |
#27072 11/12/2003 12:17 AM | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | The optional four barrel manifold accepts a Quadrjet and has a split exhaust manifold,I passed on one of those setups years ago that was cheap cause the owner did not know what it fit. I was eyeing it to see if I could adapt it to a 235 and I wish I would of bought it anyway. | | |
