| | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#26853 01/17/2002 2:00 AM | Joined: Dec 2001 Posts: 92 Member | | Member Joined: Dec 2001 Posts: 92 | The flywheel marks are aligned, the rotor is pointing to #1 cyl, dang thing keeps backfiring thru the carb. Thought it was 180 degrees out tried that still the same result.Checked tonite in total darkness to see if fire is flying from dist. cap or elsewhere.No problem there. Could it be a valve hung open???? Stumped :mad: :mad:
Live every day to the fullest for tommorrow never comes!!!
#26854 01/17/2002 2:27 AM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Alan..... Is this somrthing you just got together?If not what things did you do just prior to the problem? | | |
#26855 01/17/2002 3:00 AM | Joined: Dec 2001 Posts: 92 Member | | Member Joined: Dec 2001 Posts: 92 | jh,
the truck has been parked for 2 yrs I just got the exhaust put on it so I was ready to get the engine running, didnt crank it without an exhaust system,so basically the only things new is a new carb, and the exhaust system. the engine has been built already.
#26856 01/17/2002 3:14 AM | Joined: Dec 2000 Posts: 64 Member | | Member Joined: Dec 2000 Posts: 64 | You may want to check to make sure the plug wires are on the correct cylinder. If you have no.3&4 changed around it will backfire through the carb. also make sure the distributor cap doesn't have a crack from one cylinder to another.
kdot em3
#26857 01/17/2002 4:13 AM | Joined: Dec 2001 Posts: 92 Member | | Member Joined: Dec 2001 Posts: 92 | Carl,
The wires are correct, Tonite with the lights off I tried cranking the engine to see if I had any fire comming from anywhere other then the starter and none showed up. I will replace the dist cap any way and see from there. Thanks
#26858 01/17/2002 4:16 AM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Alan......
How old is the fuel? | | |
