| | | Forums66 Topics128,127 Posts1,056,357 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Okay, here's the deal... My 52, 3100 has a mid 70's 250 cid and stock 4-speed. I've tuned and retuned, replaced the fuel pump, added a clear fuel filter (so I can see what's going through the line) and am continuing to have a problem.
The truck starts pretty easily cold, and runs like the dickens when cool. However, after a drive, it's sometimes (key word here is sometimes) hard to start and then wont idle worth a darn. It even will sometimes just stop running. At other times, it starts and runs fine.
When it stops, it doesn't sputter or anything to make me believe it's a fuel issue. It just simply stops running. Most of the time, it will continue to run with pressure on the pedal.
I haven't replaced the distributor (HEI) cap and/or rotor.
I'll probably start there, but I'm curious if any of you thought it might be carb settings, or does anyone out there have any other thoughts. | | | | | Joined: Aug 2003 Posts: 28 Junior Member | | Junior Member Joined: Aug 2003 Posts: 28 | Jed
It seems like its the 52 chevies from hell night. Wish I knew the solution for either one of ours, but I sure don't. Somebody here will though I bet. Good luck. harry | | |
#2677 09/12/2004 10:23 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Wild guess #1 .
Is the fuel cap properly vented ? | | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Dusty, I can't say that I would have even looked in that direction. Guess I'll check that out today. Thanks for the pointer. Anyone Else????? | | | | | Joined: May 2003 Posts: 77 Member | | Member Joined: May 2003 Posts: 77 | Another thought would be to check the vacumn advance on the distridbutor to see if it is functioning properly. I had one once that was stuck and had the timining fully advanced right from idle! Not knowing this I retarded the initial timing. This made the thing run somewhat in the same way you described that yours does. Take a timing light to it and see if the timing advances when you rev it up. If it doesn't, then what I described is the problem! This one had me scratching my head for several days! :confused:
Just trying to avoid the potholes on the road of life!
49 Chevy COE 55 Chevy pickup + way too many other project vehicles!
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Replace the module in the HEI. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Thanks for the suggestions COE Junkie, and Wrenchbender. I'll have to track down the timing light and see what happens. I'm somewhat naive, so pardon the ignorance... If the scenario you described is the cause, what's the cure. Also, Wrenchbender, if you don't mind. How would temperature affect the engines running in this manner? | | |
#2682 09/12/2004 10:13 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Electronic components are very heat sensitive. In fact there is a small amount of silicone compound under the module to transfer heat. If this is not put on the new part will fail in short time. The way your engine dies without sputtering makes me believe it is ignition related. The module is generally the culprate in this case. Unless you have elaborate test equipment you should try another one.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Wrenchbender. Thanks for the lesson. I'll go that route and see what happens. Appreciate the help. | | |
