1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#26676 02/13/2002 4:06 AM
hello stovebolters of america! I need your help-I have some casting numbers and I need to identify what it is and what it came from?
top: GM n
casting # 22522678 also there is a k10 in the lower area below the casting number on the right side and on the left is this ....g25
on the very top is this D N with a circle or some type of round time mark?
any clues or web sites would be great. This rear has DIsc Brakes
#26677 02/13/2002 7:14 AM
Does it have a rear pan? How many bolts holding it on? How many studs hold the wheels on?
Try pulling the pan and read the numbers on the ring gear. It will have the date code and number of teeth on ring and pinion ( 10 - 41)etc.... You may also be able to measure the ring gear size. Joe
#26678 02/13/2002 3:44 PM
joe it has 10 bolts and the wheel studs are 5on 4-3/4 . I will check for a axle code which I believe should be on the passenger side axle tude, mid way up? If not I'll call a gm service rep and give him the numbers.
thank you Joe
