7 members (TexasFarmTruck, Otto Skorzeny, MOTOXFAMILY, Phak1, kurbside bolter, 2 invisible), 157 guests, and 3 robots.
Topics128,268
Posts1,058,378
Members48,485
#26533 02/22/2003 7:22 AM
Need some help want to change front wheel bearings from original ball bearings to roller bearings if someone has a number and make I could get them locally. Need numbers for both inner and outer, I have a 45 GMC 1/2 ton.
#26534 02/22/2003 5:51 PM
I believe the roller bearings are special units sold from old truck vendors and not commonly available in local auto or bearing parts houses.The stock ball bearings work just as well if in good shape.We had a good discussion last year on bearings, some guys with knowledge stated the roller bearing offered no advantage unless they are less expensive.
#26535 02/26/2003 1:34 PM
45- I just bought those bearings from a truck parts company - I kept the boxes and #'s ...made in Japan, if I remember correctly. I'm at work now but will post manuf & #'s off box when I get home PM.
#26536 02/28/2003 4:35 PM
The inner front bearing is branded "MBS" and is # 909052R. The outer is also MBS & # 909001R. The seal is a "Federal Mogul" # 6064. The MBS says made in Japan, and the cones and cups are packaged together as a set. They fit great. Hope this helps - let us know if you find them at a local bearing house.
#26537 02/28/2003 7:22 PM
Interesting web page... :p :p
Japanese Bearing Manufacturer
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
#26538 03/02/2003 4:39 AM
Thanks guys for your help in giving bearing #s,and for the site of MBS bearings. Would have got back sooner but forgot I'd posted for the information. Yopu can always trust on the STOVEBOLTERS.
#26539 03/03/2003 3:06 PM
That's a neat site, blue. I printed the dimensions for the truck bearings, just in case I need them for reference.
#26540 03/04/2003 2:52 AM
I goofed up - the #'s above are for an AD truck - not sure about the 45. Would be worth checking the Japanese site.
